Fatal Error
  • Please log in to reply
No replies to this topic
  • Members
  • 1 posts
Posted 17 August 2004 - 23:58
I have been running into a bit of a problem here for the past couple of days. I am given the following error when I try to click on many of the items in the Installation Designer menu:
Exception ACCESS_VIOLATION (0xc0000005)
at address 0x73dd3eba trying to read address 0x0000001d.
File : C:\Program Files\InstallShield X\System\isdev.exe
Version :
Exception : c0000005
Address : 73dd3eba
Access Type : read
Access Address : 0000001d
Registers : EAX=00000029 CS=001b EIP=73dd3eba EFLGS=00010202
: EBX=00000000 SS=0023 ESP=0012ee14 EBP=0012ee3c
: ECX=0012f098 DS=0023 ESI=0012f098 FS=003b
: EDX=00cae6e0 ES=0023 EDI=00cae720 GS=0000
Stack Trace : 64491a8e 64493cdf 6449420c 682db4bb
: 682de135 682dde02 682ddd58 73e2e52a
: 73dd22ae 73dd2c25 73dd2ba2 73dd32fe
: 73dd1df0 73dd1cea 73dd1c73 73dd1bfb
: 682e1896 77d43a50 77d43b1f 77d444f5
: 77d44525 77f75da3 77d45f55 73e39c33
The items that give me problems are:
-Update Service
-Internet Information Services
-Custom Actions
-System Search
-Patch Design
-MSI Debugger
-Any of the tables in the MSI Direct Editor
I also get a "Stop Statement Encountered" message when I click on the Property Manager. This warning is coupled with one of those little white squares that contains a smaller blue square, red circle, and green triangle, like it can't load an image. I get the same image when I click on Path Variables, sans the warning message.
If I uninstall InstallShield, then reinstall it, things work for a while. However, after doing this three times in as many days, it would be nice if I could figure out how to get around the problem entirely. Any ideas as to how I can fix this? Or perhaps you have seen/heard of this issue before?
Edited by AFHCAN, 17 August 2004 - 23:59.
