Handling IIS virtual directory using InstallScript
  • Please log in to reply
#1 sathishc_cit
sathishc_cit
  • Members
  • 3 posts
Posted 22 November 2004 - 05:09
I am a beginner to InstallShield. I am developing a Standard project using InstallShield Developer 7.0.
Will anyone please help me know how to create and remove virtual directory during run-time using InstallScript?
Also, I want to know if there is a possibility to change the IIS virtual directory's properties during runtime using InstallScript.
Thanks.
- Sathish
#2 Xitch13
Xitch13
  • Members
  • 134 posts
Posted 01 December 2004 - 18:36
There really is not any support for Virtual Directories in IS Pro 7. Apparently, The 9.5 version does have support, but I wasn't williong to spend another $1000 to get that version right after I bought 7.
I use vbscript to create the directories and set permissions for the virtual directories I need. You can find pretty good tutorials over at MSDN, but I also included what I use to get you started. (Note: the vbscript is just plain ugly but it works and I never went back to clean it up.)
I launch my script with these lines of code in the installer
CODE
szLaunchApp = WINSYSDIR^"wscript.exe";
szCmdLine = SUPPORTDIR^"vdcreator.vbs";
nResult =LaunchAppAndWait(szLaunchApp,szCmdLine,LAAW_OPTION_WAIT|LAAW_OPTION_HIDDEN);
I make sure I use wscript to launch the vbs file to ensure that the host machine did not turn off support for vbscript for security reasons
and here is the code in vdcreator.vbs
CODE
' File name: CreateIISApp.vbs
' Set some variables and constants we will use...
Dim strVirtualDirectoryName1 'IIS Virtual Directory Name
Dim strVirtualDirectoryName2 'IIS Virtual Directory Name
Dim strVirtualDirectoryName3 'IIS Virtual Directory Name
Dim blnInProcessApplication 'IIS In Process Application Flag
Dim objIIS 'ADSI IIS Object
Dim strVirtualDirectoryPath1 'IIS Virtual Directory Path
Dim strVirtualDirectoryPath2 'IIS Virtual Directory Path
Dim strVirtualDirectoryPath3 'IIS Virtual Directory Path
Dim objFileSystem 'VBScript FileSystemObject
Dim strOwner 'NT Folder Owner
Dim objVirtualDirectory1 'ADSI IIS Virtual Directory Object
Dim objVirtualDirectory2 'ADSI IIS Virtual Directory Object
Dim objVirtualDirectory3 'ADSI IIS Virtual Directory Object
Dim blnScriptPermissions 'IIS script permissions flag
Dim blnExecutePermissions ' IIS Execute permissions flag
Dim blnWritePermissions '
Dim blnReadPermissions '
Dim strHTTPReferer 'IIS Referrer Page
Dim objWSH 'Windows Scripting Host Object
Dim objRTC 'Return
Dim strACLCommand 'Command Line string to set ACLs
Dim MachineName ' computer name
strVirtualDirectoryName1 = "evConfigurationService"
strVirtualDirectoryName2 = "evTransactionService"
strVirtualDirectoryName3 = "evAccountService"
' Get the Computer name using Wscript.Network and assign to IUSR to create IIS IUSR account name
Set WshNetwork = WScript.CreateObject("WScript.Network")
MachineName=WshNetwork.ComputerName
strOwner = "IUSR_" & MachineName
Set WshNetwork = Nothing
set wsc = Wscript.CreateObject("WScript.Shell")
blnScriptPermissions = "True"
blnExecutePermissions = "True"
blnWritePermissions = "True"
blnReadPermissions = "True"
' Does this IIS application already exist in the metabase?
On Error Resume Next
Set objIIS = GetObject("IIS://localhost/W3SVC/1/Root/" & strVirtualDirectoryName1)
If Err.Number = 0 Then
Wscript.echo ("An application with this name already exists. ")
Wscript.quit
End If
Set objIIS = Nothing
Set objIIS = GetObject("IIS://localhost/W3SVC/1/Root/" & strVirtualDirectoryName2)
Wscript.quit
End If
Set objIIS = GetObject("IIS://localhost/W3SVC/1/Root/" & strVirtualDirectoryName3)
Wscript.quit
End If
'Now use IIS administration objects to create the IIS application in the metabase.
'Create the IIS application
Set objIIS = GetObject("IIS://localhost/W3SVC/1/Root")
strVirtualDirectoryPath1 = objIIS.Path & "\" & strVirtualDirectoryName1
' First check for and optionally create the physical folder under wwwroot
Set objFileSystem = Wscript.CreateObject("Scripting.FileSystemObject")
Set Folder = objFileSystem.GetFolder(strVirtualDirectoryPath1)
If Hex(Err.number) = "4C" Then
set f= objFileSystem.CreateFolder(strVirtualDirectoryPath1)
End If
Set objFileSystem = Nothing
strVirtualDirectoryPath2 = objIIS.Path & "\" & strVirtualDirectoryName2
Set Folder = objFileSystem.GetFolder(strVirtualDirectoryPath2)
set f= objFileSystem.CreateFolder(strVirtualDirectoryPath2)
End If
strVirtualDirectoryPath3 = objIIS.Path & "\" & strVirtualDirectoryName3
Set Folder = objFileSystem.GetFolder(strVirtualDirectoryPath3)
set f= objFileSystem.CreateFolder(strVirtualDirectoryPath3)
End If
'Using IIS Administration object , turn on script/execute permissions and define the virtual directory as an 'in-process application.
Set objVirtualDirectory1 = objIIS.Create("IISWebVirtualDir", strVirtualDirectoryName1)
objVirtualDirectory1.AccessScript = blnScriptPermissions
objVirtualDirectory1.Path = strVirtualDirectoryPath1
objVirtualDirectory1.AppCreate blnInProcessApplication
objVirtualDirectory1.AccessWrite = blnWritePermissions
objVirtualDirectory1.AccessRead = blnReadPermissions
objVirtualDirectory1.AccessExecute = blnExecutePermissions
objVirtualDirectory1.AuthAnonymous =True
objVirtualDirectory1.AnonymousUserName=strOwner
objVirtualDirectory1.AnonymousPasswordSync=True
objVirtualDirectory1.AppCreate (True)
objVirtualDirectory1.SetInfo
'Set Change Permissions for the owner using CACLS.exe
' need to "|" pipe the "Y" yes answer to the command "Are you sure?" prompt for this to work (see KB: Q135268 )
strACLCommand = "cmd /c echo y| CACLS "
strACLCommand = strACLCommand & strVirtualDirectoryPath1
strACLCommand = strACLCommand & " /g " & strOwner & ":C"
Set objWSH = Server.CreateObject("WScript.Shell")
objRTC = objWSH.Run (strACLCommand , 0, True)
Set objWSH = Nothing
Set objVirtualDirectory2 = objIIS.Create("IISWebVirtualDir", strVirtualDirectoryName2)
objVirtualDirectory2.AccessScript = blnScriptPermissions
objVirtualDirectory2.Path = strVirtualDirectoryPath2
objVirtualDirectory2.AppCreate blnInProcessApplication
objVirtualDirectory2.AccessWrite = blnWritePermissions
objVirtualDirectory2.AccessRead = blnReadPermissions
objVirtualDirectory2.AccessExecute = blnExecutePermissions
objVirtualDirectory2.AuthAnonymous =True
objVirtualDirectory2.AnonymousUserName=strOwner
objVirtualDirectory2.AnonymousPasswordSync=True
objVirtualDirectory2.AppCreate (True)
objVirtualDirectory2.SetInfo
strACLCommand = strACLCommand & strVirtualDirectoryPath2
Set objVirtualDirectory3 = objIIS.Create("IISWebVirtualDir", strVirtualDirectoryName3)
objVirtualDirectory3.AccessScript = blnScriptPermissions
objVirtualDirectory3.Path = strVirtualDirectoryPath3
' Added the next line since the above line does not always work
'objVirtualDirectory3.Put "Path", (strVirtualDirectoryPath3)
objVirtualDirectory3.AppCreate blnInProcessApplication
objVirtualDirectory3.AccessWrite = blnWritePermissions
objVirtualDirectory3.AccessRead = blnReadPermissions
objVirtualDirectory3.AccessExecute = blnExecutePermissions
objVirtualDirectory3.AuthAnonymous =True
objVirtualDirectory3.AnonymousUserName=strOwner
objVirtualDirectory3.AnonymousPasswordSync=True
objVirtualDirectory3.AppCreate (True)
objVirtualDirectory3.SetInfo
strACLCommand = strACLCommand & strVirtualDirectoryPath3
HTH
