Inactivate cancel button in prerequisite
  • Please log in to reply
10 replies to this topic
#1 Tnaidu
Tnaidu
  • 7 posts
Posted 28 July 2008 - 14:40
Hello All,
Please give me suggestions regarding my query....?
How to Inactivate cancel button in prerequisite window ?,
i want to install one prerequisite ,with that i want to install prerequisite forcefully without user interaction means we dont want cancel button,
so please give suggestion how to inactivate cancel button from prerequisite window..?
Thanks in advance,
--Tnaidu.
#2 luke_s
luke_s
  • 532 posts
Posted 31 July 2008 - 01:37
Use the ControlCondition table to hide/disable the cancel button when the prerequisite property is set to true.
#3 Tnaidu
Tnaidu
  • 7 posts
Posted 31 July 2008 - 13:37
Hi Luke Thanks For Your help,
But prerequisite window is not present in the ControlCondition table,
so please give suggestion in this situation.
Or
Is it possible to hide the prerequisite window, i am using the IS11 basic msi.
Thanks in Advance,
--Tnaidu.
Edited by Tnaidu, 31 July 2008 - 13:37.
#4 luke_s
luke_s
  • 532 posts
Posted 31 July 2008 - 22:31
Prerequisite window?
If you are using a basic msi, how have you created your set up?
You can skip any dialog by making the conditions skip it on the next button of the previous dialog.
#5 VBScab
VBScab
  • 411 posts
Posted 01 August 2008 - 10:06
Luke, Tnaidu is evidently using Wise Package Studio which has a 'Prerequisite' page on which packagers can build a, er, prerequisite install. I never use it, preferring to use separate MSIs, either native (i.e. as supplied by the vendor) or re-packaged. That way, I get all the control I want.
#6 Tnaidu
Tnaidu
  • 7 posts
Posted 01 August 2008 - 14:01
Hello Vbscab,
Thanks for your reply,
I am using the IS11 Basic MSI,
is it possible to hide in IS11,
please help me we are little bit urgency.
Tnaidu.
#7 VBScab
VBScab
  • 411 posts
Posted 01 August 2008 - 14:30
QUOTE (Tnaidu @ 2008-08-01 13:01)
I don't have a clue, I'm afraid. As I said, I never set my packages up like that, preferring instead to install prerequisites via a deployment tool.
#8 Stefan Krueger
  • 12,635 posts
Posted 02 August 2008 - 15:36
The prerequisite dialog is displayed by setup.exe, before the actual msi setup is started. Therefore you can't easily change this behaviour. Also I think users should always have the option to cancel an action. What's your problem with this?
#9 Barvaz
Barvaz
  • 36 posts
Posted 15 April 2012 - 15:09
QUOTE (Stefan Krueger @ 2008-08-02 15:36)
I run my prerequisite as feature prerequisite – when the prerequisite Is running (In progress) and the user click on 'Cancel' button the prerequisite finishes the installation and only then the setup is aborted.
How can I Kill/Stop/Cancel the prerequisite installation and exit the setup? Can I?
Please advice.
#10 Stefan Krueger
  • 12,635 posts
Posted 16 April 2012 - 09:26
I don't think that's possible. InstallShield's setup.exe launches the prerequisite's setup.exe in silent mode. Now how would you abort this silently running setup?
#11 Barvaz
Barvaz
  • 36 posts
Posted 16 April 2012 - 09:41
QUOTE (Stefan Krueger @ 2012-04-16 09:26)
I'm not - During the prerequisite installation while the user click on Cancel button than the prerequisite running until the end and only than exit the setup.
