| InstallSite · E-mail and password recovery note · Contact |
Help
Search
Members
Calendar
| Welcome Guest ( Log In | Register ) | Resend Validation Email |
| Laurent COMPERE |
Posted: 2001-04-18 07:40
Group: Members Posts: 10 Member No.: 586 Joined: 2001-04-17 |
Running my setup under Win 98 SE on a new Compaq PC with no others softwares installed, the following message is displayed:
Error 1402: Could not open the key Software\\My software name\4.0.0. Verify that you have sufficient access to that key. I reinstalled Win 98 SE after formatting hard disk. Then the message is not displayed ! Any idea ? Thanks. |
| GeorgePlummer |
Posted: 2001-04-25 13:30
Group: Members Posts: 7 Member No.: 653 Joined: 2001-04-25 |
I have encountered the same error when running our previously tested installation on a Win2000 server.
The user has admin rights, and the log file seems to have stopped logging before the rollback. The last lines are.... Action ended 10:27:35: InstallFiles. Return value 1. Anyone have any ideas? |
| Kelly Russell |
Posted: 2001-05-21 19:35
Group: Members Posts: 72 Member No.: 100 Joined: 2001-02-15 |
I have a end user that is getting the same error. Has anyone figured out what is going on and how it can be resolved? Thanks
Here is some more info. Last couple lines of logfile before rollback. WriteRegistryValues: Key: I have verified that the end user has full rights to the registry. ??? Wierd. (Edited by Kelly Russell at 5:53 pm on May 31, 2001) |
| Kelly Russell |
Posted: 2001-06-12 22:41
I found this on the Install Shield site:
"Installing a setup that included the Access97 object on a machine where the company name was not set resulted in run time error 1402." So just need to fill in organization name on "Customer Information" dialog box to fix the problem. This infomation is usually filled in by InstallShield if present, here is where it gets the info: for 95, 98: for NT, W2K: |
| End User |
Posted: 2008-10-18 09:36
Group: Full Members Posts: 1 Member No.: 14981 Joined: 2008-10-18 |
The same key for Vista 32/64. Filling organization works - the Error 1402 disappeared. Filling in the InstallShield dialog box does not work (attempt on Vista x64 SP1). I've built the key+value in my InstallShield installer, no problems, the trick has succeeded. I realize that some users will be angry if they find their organization name is changed, but... Kelly Russell, thanks, bravo, bravisimo, evallah, спасибо, mersi, danke, благодаря! This post has been edited by End User on 2008-10-18 09:52 |
| VBScab |
Posted: 2008-10-20 08:56
Group: Full Members Posts: 375 Member No.: 11292 Joined: 2005-10-13 |
There's no need for script to achieve that. You can use SystemSearch to look for the value and set a property accordingly. Your feature or component can then be installed depending on that property's content. -------------------- - Don't know why 'x' happened? Want to know why 'y' happened? ProcMon will tell you.
- Try using http://www.google.com before posting. - I answer questions only via forums. Please appreciate the time I give here and don't send me personal emails. |
