Using "InstallShield2008 Professional" I created the most simple InstallScript project (default settings, added just 2 dummy files to be installed).
When creating and running the standard Cabinet file output, everything goes fine.
But, when creating a "single-exe image" and running that, the setup still works, but after the setup finished the process ("MySingleExe.exe") is still visible in Windows Task Manager for about 30-40s.
This is not so much of a problem if the setup is run separately, but this setup is called by another setup (a "master setup") and this master setup waits (-->LaunchAppAndWait) until the sub-setup finishes and I can't let the user wait 30-40s until the master setup continues.
Any ideas ? What can delay a single-exe Setup from shutting down its process ?
Thanks for your help !
Jürgen
Single EXE setup needs long to exit
jyrki
, Jan 15 2008 11:37
Posted 16 January 2008 - 11:06
The self extracting exe cleans up the temp files when it's done. I guess the only thing you could try to avoid this is to keep the temp files permanently.
