Hi all,
I'm using IS 2009 to make a Basic MSI installer, and would like to install files to a folder with a version number. Example, I'd like to put files in:
C:\Program Files\Company\Product\n.n.n\folderA
but I'd like the 'n.n.n' to be the [ProductVersion] property that's in Property Manager.
I tried a few ways but could not get it to work. Is this possible?
ksh
Set install path via a property/variable?
kshahn
, Dec 09 2008 20:25
Posted 11 December 2008 - 09:59
I think it is.
You set the "version number" directory (say, VERSIONFOLDER) to some fixed value using the Directory table. Then you create a Directory table entry for your folderA as:
Directory=FOLDERA
Directory_Parent=VERSIONFOLDER
Default_Dir=folderA
Then you define a custom action of type 51 (set a property) which sets the property VERSIONFOLDER to the path of this version folder, i.e. C:\ProgramFiles\company\Product\[ProductVersion]
This custom action must be scheduled before the CostFinalize Action.
Best regards
Matthias
Directory=FOLDERA
Default_Dir=folderA
Best regards
Matthias
Posted 07 May 2009 - 16:23
I have a similar problem that i have been banging my head around for two days now;
Here is what i want to do: I need to install things to two places:
1. Programs are to go to [INSTALLDIR] eg c:\program files\myApps
No problem with that.
2. Some user files are to go to CommonAppData\myApps.
No problem with that either, 'myApps' is the default.
But - the user can change [INSTALLDIR] to say c:\program files\FRED\.
If they do this then the user files must go to CommonAppData\FRED.
So at runtime, i have a CA running as a DoAction on the Next button on DestinationDialog. This CA parses FRED out of INSTALLDIR by seeing what comes after c:\PRogram Files\ string, and sets a property called USERFOLDER (which is actually a Directory Table item) to CommonAppData\FRED. THis CA does seem to run AFTER CostFinalize which is where i think it is supposed to be. I use MsiSetTargetPath()
But in my final installed folder structure i do not get FRED but i get a folder called [USERFOLDER] ie the property in Directory table has not been resolved. Is that becasue i am doing things at the wrong sequence? Is there another better way, given i don't know till runtime the Property.
Here is part of my Directory Table:
Directory - (s72) - Parent -- DefaultDir
_USERFOLDER_ - CommonAppDataFolder - _USERF~1|[USERFOLDER]
USERFOLDER - CommonAppDataFolder - DEFAUL~1|Default Place
thanks
andy
thanks
andy
Edited by andyguest13, 07 May 2009 - 16:40.
Posted 08 May 2009 - 08:50
Duplicate post - please reply here: http://forum.install...t=0
