I've been trying to use the function MsiQueryProductState or property Installer.ProductState to check if an MSI product is installed.
I checked msi.h to see what constants I would need if I wanted to use the COM object Installer.ProductState in a vbscript and I came across something I thought was strange.
in msi.h they declare
typedef enum tagINSTALLSTATE
INSTALLSTATE_ADVERTISED = 1
INSTALLSTATE_REMOVED = 1
If the function returns 1 how do I know if the product is either advertised or removed or am I missing something here?
cheers
vengeanz
Checking to see if a product is installed
vengeanz
, Oct 24 2006 21:07
Posted 30 October 2006 - 12:17
For situations like this I've simply set a new row in the Upgrade table with a flag for OnlyDetect. This will find your product and set a property accordingly that you can then detect within your package (after AppSearch in your sequence) to see if the other product(s) is present on the system or not.
Regards,
Gareth
Regards,
Gareth
Posted 02 November 2006 - 08:55
Hey Gareth,
Thanks for your reply.
In this situation I wanted to check if the product is installed from VBscript or C code, without actually running any specific MSI package.
I think I can do this, but I was wondering why the enum in the msi.h file has two (and I would have thought distinct) install states having the same value.
The way I see it Advertised is a form of Installed Product whereas Removed is ... well, removed.
so if I get a 1 back from either function is my product installed or not?
Cheers
vengeanz
Cheers
vengeanz
Posted 02 November 2006 - 14:07
The return type INSTALLSTATE is used for multiple functions. In this case, INSTALLSTATE_REMOVED can be returned from MsiGetComponentState, in which case it means that the component is about to be removed. Note that components can never be advertised - only features can.
When a product is not installed, MsiQueryProductState returns INSTALLSTATE_ABSENT. This value is also returned when the product was installed some time ago, but not anymore.
BTW You can also search on products using an upgrade code - look at MsiEnumRelatedProducts.
