Hi there,
When you run a silent install, you can specify the location of the setup.log with the -f2 commandline switch.
Does anybody know if there is a function or system variable with which you can obtain the location of this file ?
Thnx, Ide
Location of silent log
Ide Nentjes
, Oct 30 2002 13:44
Posted 31 October 2002 - 12:06
Why not search CMDLINE itself for -f2 and extract the trailing path/filename?
Posted 31 October 2002 - 12:12
Because IShield strips CMDLINE of all standard commandline options. Alas, only custom written options are present in CMDLINE and as such the -f2 switch is not present.
