Hi All
Using the ComAdmincatalog object I have created a com+ package through custom action.I don't know how to delete the package during uninstallation of the product.
Please help me out.
How to delete a com+ package during uninstallation
Hemamalini
, Mar 22 2002 06:35
Posted 22 March 2002 - 19:03
Here is an edited one I use. I actually have a few apps that I delete and I also capture some of the information on one of the Apps, and I'm just parsing out a DbConstructor string, that is mainly what I edited out.
This grabs the name of your COM+ App from a property and first shuts it down, and then removes it from the Catalog. This however does NOT uninstall the component and delet its files. I install mine via a Nested install, but I do this when attempting to upgrade the install because if the app is active you get errors running the install.
| Code Sample |
Sub DeleteCOMPlusApps Dim Catalog Dim Applications Dim AppObject Dim Components, ComObject Dim sAppName Dim sNames Dim i, x sAppName = Session.Property("COMPLUSAPP") 'First, we create the catalog object Set Catalog = CreateObject("COMAdmin.COMAdminCatalog.1") 'just to be safe, shutdown the COM+ app On Error Resume Next Catalog.ShutdownApplication(sAppName) Err.Clear On Error Goto 0 ' Get the Applications collection and populate it Set Applications = Catalog.GetCollection("Applications") Applications.Populate For x = 0 To Applications.Count - 1 If Applications.Item(x).Name = sAppName Then Call Applications.Remove(x) Exit For End If Next Applications.SaveChanges End sub |
