One click install gives run-time error after trying to save to a target location. The installation includes files to be installed placed in sub-folders through the CDROM Folder option in Features and the release wizard used the custom media layout. This layout allows storing some features in .cab's and others in specified CD-ROM folders.
We need to have the install files structured in sub-folders in order to support CD-ROM install and also in order to run an application from CD. One-Click install works when the run-option is chosen after executing the setup.htm generated by DevStudio. Although saving the install gives run-time error. We need customers to be able to download and save the setup to a target location before actually installing the product.
Any solutions or ideas is very appreciated.
Thanks in advance.
SKL
One click install gives run-time error in save
SKL
, Dec 19 2003 19:15
Posted 20 December 2003 - 08:07
What error message?
Does your setup contain any files that might conflicht with HTTP (e.g. with blanks ort special characters)?
Posted 22 December 2003 - 19:50
Thanks for your reply. The following is the error message displayed in a pop-up dialog while running the setup:
"Setup.exe has generated errors and will be closed by Windows. You will need to restart the program. An error log is being created".
I couldn't locate the error log file. I'm trying the the scenario I'd mentioned with a test application with just one component having dll's but I still get the same error.
I'm pretty sure we're not using any special character files.
Any solutions or leads will be very helpful.
SKL
SKL
Posted 23 December 2003 - 08:08
So the setup works properly when run locally but crashes when run from HTTP? Could there be some firewall, anti-virus software or somthing like that corrupting the file during download? (Did you clear your browser cache?)
