fehler während komponentenübertragung
Posted 05 June 2001 - 13:50
ich bekomme immer einen fehler, wenn ich als normaler user unter w2k mein prog deinstallieren will. er löscht alles ausser den shortcut auf dem desktop und das verzeichnis in dem das prog drin war.
dann kommt ne meldung, dass der zugriff verweigert wurde.
Posted 05 June 2001 - 14:11
when uninstalling my prog as a normal user on w2k it deletes everything expect the shortcut on desktop and the directory of where the prog was installed in.
then there will be a message that tells me componenttransfer error reason: access denied
... the prog was installed as normal w2k user
Posted 05 June 2001 - 14:13
@flo: maybe you dont have the right to remove desktop the desctop icon. the installation directory i have to delete by my own (from script, in uninstalled-event) because IS leaves it untouched. dont know why.
Posted 05 June 2001 - 14:20
the installation dir i delete on my own too (script)
that´s trouble too.
it doesn´t delete it (deutsch: sofort). it´s locked i have to reboot after that it deletes this directory
Posted 05 June 2001 - 14:37
The directory being left may be because you have umbrellaed with more than one layer... By that I mean, your TARGETDIR is like PROGRAMFILES^"COMPANY NAME"^"PR0DUCT NAME". What happens is that IS thinks it only created the lowest level; not PROGRAMFILES^"COMPANY NAME". What you can do is after you have had the user enter the destination for TARGETDIR, make each dir starting with the highest...
CreateDir(PROGRAMFILES^"COMPANY NAME");
CreateDir(PROGRAMFILES^"COMPANY NAME"^"PRODUCT NAME");
This gets a little complicated if the user selects an unstandard path so what I do is simply check that "COMPANY NAME"^"PRODUCT NAME" is contained in the TARGETDIR. if not I don't do the above code. Even then, I still do a reset of all files/dirs underneath the TARGETDIR and a manual delete of the TARGETDIR on uninstall...be sure to check that you have the correct TARGETDIR before deleting. If you use deletedir and the dir param passed is "", 9x machines think that means the windir and you will blow away the os. Eeek!!!
Posted 05 June 2001 - 14:45
