Installation Dying
Posted 12 November 2004 - 21:12
Now the install begins correctly. It will ask him which install he wants to use (Typical, Custom…etc) and he’ll choose it and it will move along as normal. The install then appears as if it’s copying files because the progress bar will start to move. The progress bar gets to 100%, the window that says Registering Product comes up, and then the install dies. The Install Window disappears and returns the customer to his desktop. I’ve had him check the running processes and nothing related to the install is running in the background. InstallShield just up and quits.
I’ve had the customer clean out his Temp folder. I’ve had the customer register both the MISEXEC.EXE and the IDRIVER.EXE files and then re-run the setup. Same problem. I’ve had the customer log in using both his and the Admin account. Same problem. I’ve had him run the ISSCRIPT.MSI, and then try to install. Same problem. I had him download the Windows Installer Cleanup app and check for our product. It is not found.
The install is crashing before any of our product's files or registry settings are being written to the machine. I had him do a manual search of the registry for references to our product. No entries. I had his hard drive for files related to our product. None found.
Install created with Developer 7 SP4.
Suggestions?
Posted 13 November 2004 - 15:06
Posted 14 November 2004 - 00:07
Posted 15 November 2004 - 22:48
The first thing that seems odd, when comparing the log from this user to a log of a successful setup, is something about a Leaked MSIHANDLE. There are entries like the section below from (166) down to (28). After the Leaked MSIHANDLE references are done, it appears to continue on with a long list of the install's Properties. After the list of Properties, the install fails, returning 1708 then 1602. Please see the portions of the log file below.
MSI © (48:2C) [10:24:05:687]: MsiProvideComponentFromDescriptor is returning: 0
1: MsiServerStartup ends
MSI (s) (A8!AC) [10:24:05:697]: Leaked MSIHANDLE (166) of type 790531 for thread 428
MSI (s) (A8!AC) [10:24:05:697]: Leaked MSIHANDLE (165) of type 790531 for thread 428
MSI (s) (A8!AC) [10:24:05:697]: Leaked MSIHANDLE (164) of type 790531 for thread 428
MSI (s) (A8!AC) [10:24:05:697]: Leaked MSIHANDLE (163) of type 790531 for thread 428
MSI (s) (A8!AC) [10:24:05:697]: Leaked MSIHANDLE (162) of type 790531 for thread 428
MSI (s) (A8!AC) [10:24:05:697]: Leaked MSIHANDLE (161) of type 790531 for thread 428
~<INSERT the rest of the Leaded MSIHANDLE lines here>~
MSI (s) (A8!AC) [10:24:05:707]: Leaked MSIHANDLE (29) of type 790531 for thread 428
MSI (s) (A8!AC) [10:24:05:707]: Leaked MSIHANDLE (28) of type 790531 for thread 428
1: RPC server shut down.
Action ended 10:24:05: ISCleanUpUserTerminate. Return value 1.
Action ended 10:24:05: INSTALL. Return value 2.
Action ended 10:24:05: ISMsiServerStartup. Return value 0.
Property(S): DCOMISPRESENT = 1
Property(S): CURRENTDATE = 11-15-2004 10:22:57
~<INSERT the rest of the Property(S) lines here>~
Property(S): IEVERSION = 6.0.2900.2518
Property(S): ProductToBeRegistered = 1
MSI (s) (A8:18) [10:24:06:068]: Note: 1: 1708
MSI (s) (A8:18) [10:24:06:068]: Product: <My Product's Name Goes Here> -- Installation operation failed.
MSI (s) (A8:18) [10:24:06:078]: Cleaning up uninstalled install packages, if any exist
MSI (s) (A8:18) [10:24:06:078]: MainEngineThread is returning 1602
MSI (s) (A8:60) [10:24:06:078]: Destroying RemoteAPI object.
MSI (s) (A8:88) [10:24:06:078]: Custom Action Manager thread ending.
=== Logging stopped: 11/15/2004 10:24:06 ===
MSI © (48:44) [10:24:06:098]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI © (48:44) [10:24:06:098]: MainEngineThread is returning 1602
=== Verbose logging stopped: 11/15/2004 10:24:06 ===
Any ideas?
Posted 16 November 2004 - 08:58
1708 means "Installation operation failed." but doesn't give any information about the reason.
I think there must be some action with a return value other than 0 or 1 earlier in the log.
Posted 16 November 2004 - 18:03
MSI © (48:2C) [10:24:00:510]: MsiProvideComponentFromDescriptor is returning: 0
MSI (s) (A8:18) [10:24:00:510]: Executing op: CustomActionSchedule(Action=OnMoved,ActionType=3073,Source=BinaryData,Target=Moved,)
MSI (s) (A8:38) [10:24:00:520]: Invoking remote custom action. DLL: C:\WINNT\Installer\MSI34.tmp, Entrypoint: Moved
MSI © (48:5C) [10:24:00:971]: Entering MsiProvideComponentFromDescriptor. Descriptor: o9npMj8*2=sT_Bx}J{FvScannedProject>M5KDYSUnf(HA*L[xeX)y, PathBuf: 413F4BC, pcchPathBuf: 413F4B8, pcchArgsOffset: 413F418
MSI © (48:5C) [10:24:00:971]: MsiProvideComponentFromDescriptor called for component {997FA962-E067-11D1-9396-00A0C90F27F9}: returning harcoded oleaut32.dll value
MSI © (48:5C) [10:24:00:971]: MsiProvideComponentFromDescriptor is returning: 0
MSI © (48:5C) [10:24:00:971]: Entering MsiProvideComponentFromDescriptor. Descriptor: o9npMj8*2=sT_Bx}J{FvScannedProject>M5KDYSUnf(HA*L[xeX)y, PathBuf: 413EE28, pcchPathBuf: 413EE24, pcchArgsOffset: 413ED84
MSI (s) (A8:18) [10:24:00:981]: User policy value 'DisableRollback' is 0
MSI (s) (A8:18) [10:24:00:981]: Machine policy value 'DisableRollback' is 0
Action ended 10:24:00: InstallFinalize. Return value 2.
MSI (s) (A8:18) [10:24:00:991]: Executing op: Header(Signature=1397708873,Version=300,Timestamp=829379307,LangId=1033,Platform=0,ScriptType=2,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
MSI (s) (A8:18) [10:24:00:991]: Executing op: DialogInfo(Type=0,Argument=1033)
MSI (s) (A8:18) [10:24:00:991]: Executing op: DialogInfo(Type=1,Argument=<<My Product Name Here>> Professional Edition 6.2)
Posted 16 November 2004 - 18:30
Posted 16 November 2004 - 18:50
http://community.ins...ad.php?t=139045
The common thread among the problems seems to be XP SP2. I guess I'm going to have our tech support people have the customer try uninstalling SP2 (using XP Home SP2) and see if that magically fixes anything.
At any rate, my complete log file was attached to my last post there if you're interested in checking it out.
Posted 17 November 2004 - 00:53
Posted 18 November 2004 - 09:24
BTW your log didn't attach, maybe it was too big (limit is 100 K, please try and ZIP it next time)
Posted 18 November 2004 - 17:14
Posted 22 July 2005 - 22:29
On two completely seperate software installs that use a SETUP.EXE InstallShield "package" will go through the install, even report in the EventLog that the installation was successful...even copies the files (I see them in the target directory for a brief moment), then after "Registering product ==} Publishing product..." it'll say that the InstallShield was interrupted, and all the files are removed, and an event is logged saying that the installation failed. It appears that Quicken 2005 is probably a third install that is exhibiting this behavior.
I've been combing the Internet looking for some explanation and workaround (other than uninstalling SP2) and haven't found any yet.
