I have component that insert keys to Registry Data.
How can I use the same component for 32bit and 64bit as well.
I do not want to duplicate the component and condition it by 64-Bit Component.
Please advice
How to install the same Component on 32 and 64bit
Barvaz
, May 22 2012 09:18
Posted 22 May 2012 - 11:02
If you want to write in the 64 bit section of the registry on 64 bit machines, you must use a separate component. If you want to write to the 32 bit section of the registry even on 64 bit machines, one 32 bit component is sufficient.
