Hi all,
The problem is a feature doesn't allow advertise but it does.
I have a minimal setup type (feature A1) and typical setup type(features A1, A2, A3) in the SetupType dialog, where
A1
Remote Installation Favor Local
Install Level 10
Display Visible and Colapsed
Advertisment Disallow Advertise
Required No
Release Flags Agent
Condition 0 conditiion(s)
A2 and A3
Install Level 100
Required No
Release Flags Full
I have two releases: Agent(Release Flags = Agent, only one feature A1 is installed) and Management Console (Release Flags = Full,Agent; features A1,A2,A3 are installed).
I have added subfeature SubA1, SubA2, SubA3 and applyied a minor upgrade from the command line like "REINSTALLMODE=vomus, REINSTALL=A1,A2,A3 ADDLOCAL=SubA1,SubA2,SubA3". I have created an installation log file.
The problem is: the SubA1 features is not install.
I checked the log file and found the follows:
A1 has been installed and then try to reinstall (minimal setyp type):
MSI (s) (C0:38): Feature: A1; Installed: Advertise; Request: Reinstall; Action: Reinstall
MSI (s) (C0:38): Feature: SubA1; Installed: Absent; Request: Null; Action: Null
A1, A2, A3 have been installed and then reinstalled (typical setup type)
MSI (s) (A8:5C): Feature: A1; Installed: Local; Request: Reinstall; Action: Reinstall
MSI (s) (A8:5C): Feature: SubA1; Installed: Absent; Request: Local; Action: Local
Why it is correct in the first way and wrong in the second? I really need to install SubA1, because I use one of it's component during the installation as executable and have an error now the file could not be found.
Any help will be great appreciated.
Advertise feature
Irina
, May 08 2002 15:04
Posted 08 May 2002 - 15:04
Irina Shirinsky
Software Engineer, Heroix Corporation
http://www.heroix.com
Posted 10 May 2002 - 15:38
I found what the problem was. I have added a new standard merge module to the exsting feature instead to add it to the new subfeature. Of course, the installation doesn't work correctly during the minor upgrading. I didn't recognize at that time that the merge module is a regular component.
Irina Shirinsky
