hi ,
Im new to this, but I am trying to understand!! Here's my problem/question. I want to check to see if Jet 4.0 and Mdac 2.6 is installed on a users machine before running a custom action. So, I am using RegdbGetKeyValueEx to check for them.
Here's what I have for Jet 4.0:
if (RegDBGetKeyValueEx (szKey, "OLEDB_SERVICES", nvType, svStringValue,nvSize) < 0) then
bJetFound=FALSE;
endif;
szKey = "SOFTWARE\\CLSID\\{dee35070-506b-11cf-b1aa-00aa00b8de95}"
But, my return value( svStringValue ) = blanks.
The Regdbgetkeyvalueex is set up to look for 2.60 ( even though I have 2.61 on my machine). Here my question is: what exactly do I look for in order to install 2.6 ? It seems that I would not want to overwrite a higher number(ie, 2.61).
Thoroughly confused here. Appreciate any tips you might have. I am just so glad I found your site.
thanks very much.
RegdbGetKeyValueEx
TreviBoy
, Jun 22 2002 19:36
Posted 12 August 2002 - 20:30
To look for a MS Jet 4.0 use
"\\SOFTWARE\\Microsoft\\Jet\\4.0\\Engines\\Jet 4.0"
and
if( RegDBKeyExist ( svRegPath ) <0 )then szReport = "Can't find "+svRegPath^svKey;
endif;
I tried to use RegDBGetKeyValueEx before and if the default says "value not set", then you get an empty key!
For MDAC 2.6 I use
svRegPath = "\\SOFTWARE\\Classes\\MDACVer.Version\\CurVer";
Both keys on HKEY_LOCAL_MACHINE.
Good luck!
and
endif;
For MDAC 2.6 I use
Good luck!
