My problem is very simple:
I'm running a major upgrade that uninstalls and then reinstalls my application.
Before the uninstall, I copy some files to FOLDER_TEMP (in a subdirectory that I create).
I then perform the uninstall (RemoveExistingProducts) and try to copy the files back... but by the time I go to do that, they're gone!
I thought that maybe it removes them because they're in the TEMP folder (although I have no idea why it would be so eager to do this halfway through the upgrade), so I tried FOLDER_PERSONAL. Nope. Poof. Gone.
What's going on here?
(I've watched C:\Doc & Settings\...\temp with windows explorer, and I actually see my files appear and then disappear)
I copy files to FOLDER_TEMP... and poof! Gone!
Alphathree33
, Mar 29 2004 22:15
Posted 30 March 2004 - 04:21
Try running the upgrade with verbose logging turned on.
msiexec /I "msipackage.msi" /L*V c:\msilog.txt
It is quite possible that your first install is actually removing the files. You should be able to see this from the install log.
Posted 30 March 2004 - 23:32
If it is removing the files, you will need to work out where this is coming from and look at fixing it
Its really hard to give advise from here since i don't know much about the install.
