I'm using Standard projects in ISD 7.03. I've a COM+ application which is shared between different products, so I put this COM+ app into a merge module. Now it happens, that I have to add or delete COM-Components to/from my COM+ app, therefore I need new versions of that merge module. Especially I need something like a "Major Upgrade" of that merge module. ( Uninstalling the older version and installing the new one ) Is that possible?
Thx in advance
Achim
Major Upgrade of merge modules
buckelfliege
, May 13 2002 15:54
Posted 14 May 2002 - 13:58
If I understand the WI system correctly, merge modules are installed as part of your main installation - they are 'merged'.
If you recompile the merge module with the stuff, then recompile your app (updating the version numbers as for a normal upgrade), it should upgrade an old installation correctly.
Let me know if this works, as I'll also need to be able to do this at some point
Cheers
John
Cheers
John
