I have multiple TextSubs which are filed durring the initial setupprocess:
TextSubSetValue(API_KEY, szApiKey, FALSE);
When I run the installer again in maintenance mode, the user can change the setting and in InstallScript, I also call the function above to save the input from the User.
I do NOT run MoveData() action in this case. If the user starts the maintenance setup again, the initial value is used when I use TextSubGetValue() and not the one which was typed in in the first maintenace run.
What function/method do i have to call to update the TextSub-Values?
