Hi All,
I've got an installer that needs to install different versions of the same files depending on a UI choice at run time... What's the 'best practice' method of doing something like this? I was thinking maybe having a component for each file and then somehow dynamically adding the approprate one to the main feature, but I'm not quite sure if that's the right way and if so how I go about it....
Cheers
Adding components dynamically at run time?
Anthony Hughes
, Mar 11 2005 13:08
