What is the best way to define custom action to call a vbs script with parameters?
calling vbs script
carlodimascio
, Feb 13 2001 02:32
Posted 13 February 2001 - 05:54
To the best of my knowledge, it isn't possible to pass parameters into a vbscript function. Instead, you set properties in install script using MsiSetProperty. You can then access these properties from your vbscript by calling:
MyLocalVar = Session.property("MyProperty")
These properties are read/write, so you can also write the properties as a replacement for return values from the script.
Hope this helps,
Leigh.
