creating Component dynamicaly
Posted 30 July 2001 - 15:58
(creating the component table at runtime ? is it possible and if yes, how to do that ?)
Any idea is welcome.
Posted 30 July 2001 - 21:52
I have done this successfully in the admin sequence (so that setup.exe instmsia.exe instntmsiw.exe and setup.ini get copied). I do not seee any reason this can not be done in the execute sequence.
Posted 31 July 2001 - 08:24
but could you tell me how to insert temporary row into a table? i saw function to create row,but i don't understand how to insert them in a table... I'm really new with installscript, so excuse my newbie question's
Posted 31 July 2001 - 08:43
// Function : ExectuteView
// Description :
static UINT ExecuteView(
MSIHANDLE hInstaller, // Handle of installer
MSIHANDLE hInfo, // Handle of our message record
MSIHANDLE hDb, // Handle of installer database
LPSTR pQuery) // SQL Query
PMSIHANDLE hView;
char text[500];
UINT Result = ERROR_SUCCESS;
BOOL Once;
for (Once=TRUE; Once; Once=FALSE)
wsprintf(text, "SQL request = %s", pQuery);
MsiRecordSetString(hInfo, 1, text);
MsiProcessMessage(hInstaller, INSTALLMESSAGE_INFO, hInfo);
Result= MsiDatabaseOpenView(hDb, pQuery, &hView);
if (Result!=ERROR_SUCCESS)
if (Result==ERROR_BAD_QUERY_SYNTAX)
wsprintf(text, "Could not open view - Bad SQL Syntax");
else if (Result==ERROR_INVALID_HANDLE)
lstrcpy(text, "Could not open view - Invalid Handle");
else
wsprintf(text, "Could not open view 'Component'- Unexpected error 0x%08X", Result);
Result = ERROR_INSTALL_FAILURE;
break;
Result = MsiViewExecute(hView, 0);
if (Result != ERROR_SUCCESS)
MsiRecordSetString(hInfo, 1, "Could not execute view");
MsiViewClose(hView);
break;
} // end for Once
return Result;
// Function : ExtraAdminComponent
// Description : Add entries to the component and file table so that the
// the file setup.exe, setup.ini, instmsiw.exe and instmsia,exe
// are copied during an administrative installation
UINT _stdcall ExtraAdminComponent(MSIHANDLE hInstaller)
PMSIHANDLE hDatabase;
BOOL Once;
PMSIHANDLE hInfo = MsiCreateRecord(2);
MsiRecordSetString(hInfo, 0, "ExtraAdminComponent: [1]");
// Open Database
hDatabase = MsiGetActiveDatabase(hInstaller);
if (hDatabase==0)
MsiRecordSetString(hInfo, 1, "Could not open database");
break;
// Add an extra component
Result = ExecuteView(hInstaller, hInfo, hDatabase,
"INSERT INTO Component "
"(Component.Component,Component.ComponentId,Component.Directory_,Component.Attributes
,Component.Condition,Component.KeyPath) "
"VALUES ('ExtraComponent','{B93C9BF1-4C2D-4DD4-BB88-96927004842A}','TARGETDIR','0','1','FXXX_SETUP
.EXE') "
"TEMPORARY");
if (Result!=ERROR_SUCCESS)break;
// Associate 'ExtraComponent' with our 'RequiredFiles' feature
"INSERT INTO FeatureComponents "
"(FeatureComponents.Feature_,FeatureComponents.Component_) "
"VALUES ('RequiredFiles','ExtraComponent') "
"TEMPORARY");
// Add Setup.exe to the file table
"INSERT INTO File "
"(File.File,File.Component_,File.FileName,File.FileSize,File.Sequence) "
"VALUES ('FXXX_SETUP.EXE','ExtraComponent','Setup.exe',102400,0) "
"TEMPORARY");
// Add Setup.ini to the file table
"INSERT INTO File "
"VALUES ('FXXX_SETUP.INI','ExtraComponent','Setup.ini',1024,0) "
"TEMPORARY");
if (Result!=ERROR_SUCCESS) break;
// Add Instmsiw.exe to file table
"INSERT INTO File "
"VALUES ('FXXY_INSTMSIW.EXE','ExtraComponent','Instmsiw.exe',1526275,0) "
"TEMPORARY");
// Add InstMsiA.exe to the file table
"INSERT INTO File "
"VALUES ('FXXZ_INSTMSIA.EXE','ExtraComponent','Instmsia.exe',1513987,0) "
"TEMPORARY");
} // end for Once
return Result;
Posted 01 August 2001 - 09:49
- Next, i would call a function from a dll ( CoCreateGuid) but i was unable to do this with installscript...
Is there someone who can help me please ?
Regards,
Posted 01 August 2001 - 12:07
You say the database is empty or do you just mean the additional component is missing? In which case just re-add it during uninstall.
I had not thought of the uninstall update repair implications. When MSI runs the cached copy and compares the registry info it will find it has a component that does not exist so it would not be surprising if it gets confused.
You may find it easier to take a step back and use the MoveFile table (dynamically) instead. This should be a lot safer. I think this may achieve what you want.
Posted 08 August 2001 - 16:24
Also, if you ever update this product, you want that same ComponentID, or the Windows Installer will think it is a completely new component.
If you just need to move some files dynamically, I agree that the MoveFiles table is probably a better bet.
