CAB to MSI
JackDali
, Oct 26 2004 17:27
Posted 26 October 2004 - 17:27
I have a CAB file that contains a DLL and INF file.
If I package these up within an MSI can I assume the package will execute the cab install using the INF?
Thanks for any insights ... I'm basically trying to deploy (via a GPO) the contents of the cab.
Posted 27 October 2004 - 07:15
Per-se the MSI will simply copy the CAB file. If you want it to execute the INF you will have to add a custom action that does something like rundll32 with the command line parameters to execute the inf.
Posted 28 October 2004 - 09:08
Is this a driver install or a software install? In other words: Does the INF file have a DefaultInstall section?
Posted 29 October 2004 - 16:33
Can you please tell me how to do it for software installation...
Thank you very much
Thank you very much
Posted 29 October 2004 - 17:29
Please look at sample "Install a Windows Shell INF File" at http://www.installsi.../en/isp_ext.htm. It's written in InstallScript but you should be able to produce something similar in the programming language of your choice.
