I am executing following command into command propmt for temperory use.
set EXE_FULL_PATH="C:\Users\Administrator\Documents\Visual Studio 2005\Projects\June_06_Demo\Server_Fri\Server_Fri\bin\x64Debug\
Server_Fri.exe"
REG.EXE ADD HKCR\CLSID\{f681abd0-ffff-ffff-ffff-d0f4eba19891}\LocalServer32 /ve /t REG_SZ /d %EXE_FULL_PATH% /f
regasm %EXE_FULL_PATH% /tlb:"C:\Users\Administrator\Documents\
Server_Fri\Server_Fri\bin\x64\Debug\Server_Fri.tlb"
I wants to do it while installing application. I am using Installshield 10.0 for making setup.exe.
Can you please tell me how can I get the .exe and .tlb file registered using custom action?
Unable to write custom action?
amit_bora
, Jun 20 2008 11:06
Posted 23 June 2008 - 09:13
If you really need to do this using a custom action (which is not recommended - InstallShield can register files etc. without custom action) then you could call cmd.exe and execute your .bat file as a EXE custom action.
Posted 03 July 2008 - 12:18
| QUOTE (Stefan Krueger @ 2008-06-23 09:13) |
| If you really need to do this using a custom action (which is not recommended - InstallShield can register files etc. without custom action) then you could call cmd.exe and execute your .bat file as a EXE custom action. |
Thanks Stefan.
I done this using the same way.
