Enable Maintenence in BASIC MSI
balaji4u
, Dec 08 2010 07:26
6 replies to this topic
Posted 08 December 2010 - 07:26
Hi .
I have created a BASIC MSI and installation works fine , but when i run the installer for the second time it doens't go the Maintenence mode instead again goes to the Installation mode. I am very new to INSTALLSHIELD, can anyone plz let me know how to enable Maintenence Mode in BASIC MSI.
Regards,
Balaji
Regards,
Balaji
Posted 09 December 2010 - 10:26
How do you launch the installer for the second time? From setup.exe, or double clicking the .msi file, or from Add/Remove Programs control panel?
Posted 09 December 2010 - 12:45
Hi Stefan .
I am launching it from setup.exe ... My product code , package code hasn't changed between builds but still it never goes to Maintenece mode ...Can you please help me in resolving it ...I have absolutely no idea what to do...
Posted 09 December 2010 - 12:58
Hi Stefan .
Now i packaged it as a .msi and it goes to Maintenence mode , but when created as a an setup.exe it doesn't go to this mode...How do i make it work for .exe files as well..
Regards,
Balaji
Regards,
Balaji
Posted 10 December 2010 - 17:12
But you're not trying to launch it directly from the InstallShield IDE, right?
In your media, check the setup.ini for the CmdLine= entry.
If that doesn't show the cause, create a log file to see what's going on.
Posted 13 December 2010 - 07:31
Hi Stefan ,
I couldnt figure out the root cause of this , but i created a new project and it works well and fine.But i am facing a new problem in the maintenence phase. I am using the Control event "Remove" with the argument "ALL" to remove all the features installed but the installer doesn't remove anything. I am following the installer user guide and performing everything specified there but it doesn't seems to work as it is...Can you please help ..
regards,
Balaji
regards,
Balaji
Posted 14 December 2010 - 14:06
Check the log file. Maybe some other event is resetting the value, or setting conflicting values like AddLocal or Reinstall.
