How do I get MSI handle?
finnavear
, Jun 22 2005 16:56
Posted 22 June 2005 - 16:56
A lot of functions of a .rul file I'm looking accepts the NUMBER, hMSI.
But in the file, there is no obvious use of MsiOpenPackage (or MsiOpenPackageEX) nor MsiCloseHandle to get the value of hMSI.
Code:
export prototype PrintLicenseAgreement(NUMBER);
function PrintLicenseAgreement(hMSI)
begin
end
Can someone explain to me how this works? The reason I'm asking this is because I want to use the MsiGetProperty function, and it requires the hMSI value.
Code:
begin
end
Posted 22 June 2005 - 17:31
I believe the hMSI is automatically set by installshield, it's the handle of the running instalaltion.
Posted 23 June 2005 - 19:09
Actually, I think I've figured it out.
I'm just stuck now on how I can add a Property name to my combo box.
Posted 27 June 2005 - 11:40
You can specify the property that is associated with your combo box in the dialog editor.
Posted 27 June 2005 - 11:41
Opps, my previous reply applies to Basic MSI projects. In InstallScript MSI dialogs are script driven so I think you will need to get/set the property value using script.
