I try to make a log file with setup.ini like that:
[Startup]
CmdLine=/lv C:\mylog.txt
[MSILoader]
MSIFileName=test.msi
Doesn't work!
and with MsiEnableLog() in a function of a DLL called in a custom action :
Doesn't work !
Who can help me !
Thanks.
logfile
perri.potez
, Jun 05 2002 12:38
Posted 11 June 2002 - 11:09
Thanks JSP but it doesn't work...
It seems that the log is only created when you use line command like :"setup.exe /L*v c:\mylog.txt".
setup.exe doesn't care of CmdLine in setup.ini ?
However I found this method in several pages and books.
I definitively don't know but i'm sure that i'm am fed up with microsoft !
Thanks.
Thanks.
Posted 11 June 2002 - 11:15
I can't understand why it doesn't work!
I use this every days.
Do you use a compressed package?
Don't you launch the msi?
I am really amazed of this situation.
JSP
JSP
Posted 11 June 2002 - 11:39
I must may be notify something:
I use Visual Studio Installer and not Install Shield Developer because it's for a professional software and We don't have license for InstallShield.
I'll make a little try with InstallShield Developer and look if the CmdLine parameters work.
In addition, my project is in compressed CAB, and I launch the setup.exe.
You use InstallShield Or Visual Studio Installer ?
Thanks for your help JSP.
Posted 11 June 2002 - 12:30
Again me JSP !
So logfile works with Install Shield Developer !
But it should work too with VSI. It's written by the support microsoft !! (as always).
Thanks again...
Thierry
Thanks again...
Thierry
