Hey everyone,
I'm using IS Developer 7, and I created a DSN with the program. In the settings, I have the Library Type Settings set to TCP/IP, but when I install the DSN....it gets set to Named Pipes. Does anyone have or know how I can set this manually through the script after the DSN has been installed.
I call a function that configures the server name, and was wondering if I could just do it at that time, but I'm not sure how to set it.
Alex
DSN Properties
arfinsd
, Oct 01 2002 19:55
Posted 28 October 2002 - 17:42
Just in case anyone is interested, I found the answer....
if (UseDLL( SUPPORTDIR ^ MY_DLL ) < 0) then
MessageBox("Could not load the support DLL " + MY_DLL "
into memory.", SEVERE);
else
szArgs = "DSN=MYDSNNAME|" +
"Description=My DSN|" +
"Network=DBMSSOCN|" + // Specifies TCP/IP
"Server=" + ServerName + "|";
// Replace all semicolons with NULL characters to create
// null-delimited, double-NULL terminated string, which is the
// format needed to pass to SQL functions.
szArgs = szArgs + '|';
nvLen = StrLength ( szArgs );
nvLen = nvLen - 1;
nCount = 0;
for nCount = 0 to nvLen
if ( szArgs[nCount] = '|' ) then
szArgs[nCount] = '\0';
endif;
endfor;
// This function utilizes the SQLConfigDataSource() function
// I created this function in my DLL, and it calls
// SQLConfigDataSource()....check the help for the
// parameters. The most errors come from szArgs not being
// built right.
nRes = ConfigureODBCDSN("SQL Server", szArgs);
if (nRes = FALSE) then
MessageBox ( "SQLConfigDataSource Error - Cannot
configure the SOLsearcher DSN. Please refer to the
documentation to set this up manually.", MB_OK );
endif;
if (UnUseDLL( SUPPORTDIR ^ MY_DLL ) < 0) then
MessageBox("Could not unload the support DLL " + MY_DLL
+ " from memory. Still in memory.", WARNING);
endif;
else
nvLen = nvLen - 1;
nCount = 0;
endif;
endfor;
// built right.
endif;
endif;
Alex Ferguson
www.SolimarSystems.com
Posted 28 October 2002 - 17:44
also, I could have modified the Registry directly, but found that when testing the DSN, it would fail until I clicked on "Client Configuration". As soon as I clicked this, it would work....so something was missing, I would recommend using SQLConfigDataSource() for updating the DSN....
Alex Ferguson
