probably there are msi tables/items but can i do it from ISWI?
how to remove installshield labels from dialogs?
Posted 19 June 2001 - 13:04
Posted 19 June 2001 - 18:30
Hope this helps.
SteveK.
Posted 21 June 2001 - 12:27
Basically, Export your project to a text file (.isv) and load it into your favourite text editor.
Do a Find for "DlgLine" until you find a line which looks similar to this:
"DlgLine CONTROL Cxxxxxx 1 0 Line 326 234 0 0 48"
The xxxxxx will be some number. The important part is the last 5 numbers.
Change the numbers as follows:
"DlgLine CONTROL Cxxxxxx 1 0 Line 374 234 0 1 0"
Save the file and then load it back into the IDE. You should see the line going full width.
If anyone wants to spend the time It's probably possible to work out which DlgLine relates each dialog. In the mean time it's easier just to change them all.
Posted 21 June 2001 - 19:24
When you say load it back in, is there a menu option to do that? I had ti write some VB Script to grab hold of the automation interface.
Source:
Set oProject = CreateObject("ISWiAutomation.ISWiProject")
lResult = oProject.ImportProject( "D:\code\Installations\Standard.ism", "D:\code\Installations\Standard.isv" )
Msgbox "Result [" & lResult & "]"
Posted 08 February 2002 - 04:46
This application allows to edit all the system tables used by an msi.
Bunty Parekh
Bunty_dp@hotmail.com
Posted 11 February 2002 - 08:30
Posted 12 February 2002 - 04:21
All I do is find the Install Shield Brandings and replace the text for these with my own choice of text.
Posted 12 February 2002 - 16:57
Posted 04 June 2002 - 19:17
I removed all InstallShield Brandings and replaced this with my own text in DirectEditor in Developer 7.03. But when i test the built msi, i still see only Installshield text in the brandings. And when i view the .msi in Orca or Developer, all branding texts are changed to the default Installshield text?? What am i doing wrong? Any ideas would be greatly appreciated.
Thanks in advance.
