In CustomSetup dialog I selected some components, but when I back to Maintenance I want to reset my selections to Typical.
How?
Reset selected components in CustomSetup
gloom
, Jun 25 2004 06:05
Posted 25 June 2004 - 08:41
You need to modify the feature installstate (two different states). This can be done using Installscript or VBScript, but I don't have the sample code here. Chapter 5 of Bob Baker's http://www.amazon.co...il/-/0971570833 would help you.
Edited by Glytzhkof, 25 June 2004 - 08:42.
Posted 25 June 2004 - 10:46
You mean AppLocal = "Feature1, Feature2.."?
But I have a lot of features. I think that must be a easy way?
Posted 25 June 2004 - 11:31
I can't recall if there is a way to force install of a feature and all its subfeatures. If this is possible you could add a top level feature, and force select it and all subfeatures using scripting.
Posted 25 June 2004 - 14:31
You could try calling the SetInstallLevel control event to reset feature selection.
Posted 28 June 2004 - 04:45
Danke schon Stefan!
Es ist arbeitet.
(event SetInstallLevel = 100 on PushButton)
Es ist arbeitet.
