I am using ISDev 7.02 on a Basic project. I am including a Merge Module that someone else here wrote. If there is a global property XYZ in the MM can I set it from my installation? More specifically, can I assing the property to an edit control like I can with my properties? If so, how?
Thank you,
Joe
Setting properties in MM from installation
JoeThompson
, Sep 12 2003 21:21
Posted 13 September 2003 - 09:38
Yes. However properties that are defined in merge modules typically get the module GUID appended to their name to avoid conflicts. Open the MSM in Direct Edit mode or Orca to see the real name of the property.
