Does anyone know of a product / plug in which can record the full network path of an installation?
Network Installations
Andrew sims
, Apr 06 2001 09:57
Posted 06 April 2001 - 09:57
We have to do many network installations across small networks. We need the Setup.exe to record the full network path and write it to the registry. (Currently we would only get a Windows Temp directory)
Posted 11 April 2001 - 00:21
I'm not sure of the question.
Your support directory is created in that temp dir.
I have installs in IS6 that can be put into a bat file and installed with command line switches.
What exactly are you trying to do?
Posted 17 April 2001 - 10:31
We have a team of field engieers installing software across lots of small networks (approx 5-10 PCs each). we need to log the source directory in the registry. one option is to install on the server and then a "push" install on clients. but that only logs the Windows / Temp directory not the Server itself. We need to log the server because the database is updated daily from the server.
All servers have different names / different path lengths. As i understand IS 6.22 cannot identify the source across a network but I was wondering if there is a utility / plug in that can can "detect" the full network path.
