How to set Administrator privileges???
donimoni
, Mar 25 2008 12:12
10 replies to this topic
Posted 25 March 2008 - 12:12
Hi
i need that my setup will not work unless the user has
i have tried to set the features with these conditions:
Condition:AdminUser,Level:200
OR
Condition:AdminUser,Level:100
but the setup still workes...
i need some condition that will be project releted and not feature releted,
and one that actually works.
thank you
OR
thank you
Posted 26 March 2008 - 09:12
have a look at the "LaunchCondition" table and the property "Privileged".
regards,
Udo
regards,
Udo
Posted 26 March 2008 - 14:53
isn't there a simple way from within the installshield 2008 premier
Installation designer?
Posted 26 March 2008 - 15:52
I don´t have IS2008 but in previous versions the tables can be changed in "direct editor"
Posted 01 April 2008 - 14:45
In InstallShield go to the Installation Designer tab > Instalaltion information > General information > Product Properties > Install Condition. Add a condition:
Privileged
with an appropriate error message. See attached screen shot.
Privileged
Posted 02 April 2008 - 08:06
"Privileged" is the condition i need to verify the loggedin user is Admin?
Posted 02 April 2008 - 13:57
Privileged is what typically is used. It will be set if the user is admin or has the permission to install with elevated rights. AdminUser wouldn't cover the latter, and on Vista Windows Instaler lied about AdminUser in the UI sequence to make older setups play nicely with UAC.
