In other words, I expect to have a sqlce…cab added to my .msi.
I already have it working to add the .Net Compact Framework (netcf…cab), and theoretically once this is set up correctly the sql support should follow suit – in a perfect world
Incidentally, the build proceeds fine without error or warning, it just doesn’t add the .cab. If the build fails to find/add the netcf cab it errors as expected.
-Mark
