Is there a way to retrieve the path of the .msi file programmatically that is currently being installed?
How do you retrieve the path of the .msi
maznblue
, Apr 03 2008 20:16
Posted 04 April 2008 - 09:05
Other than retrieving the entire command line string using an API call, I think the only other option would be to start the installer with the argument to create a log file and then parse that file.
Posted 04 April 2008 - 16:29
Thanks for the reply, your the log file suggestions is the only thing I could think of as well.
Posted 04 April 2008 - 16:31
The major flaw in our thinking of course is that, if one is going to run a command line, one already knows the location of the MSI!
Posted 05 April 2008 - 23:47
Depending on your situation, SourceDir might help.
