Remove old files with MajorUpgrade
Posted 20 August 2004 - 15:40
I try to execute a Major Upgrade.
ProductCode differ for Upgrade product and an Old product.
Upgrade table
UpgradeCode {18FC1E32-F0E7-455B-A1EC-10E487C37E67}
Attrubutes 5
ActionProperty UPGRADE_ACTION
I create a new property UPGRADE_ACTION
Standard Actions placed in next order InstallExecuteSequence table
CostFinalize
FindRelatedProducts
MigrateFeatureStates
InstallFinalize
ISSelfRegisterFinalize
RemoveExistingProducts
MajorUpgrade finished completely, but if I try to remove Upgrade product, files from an Old product remain in the system.
What else?
I need to completely remove all files after uninstall.
Any suggestion will be helpful.
Thank you.
Posted 23 August 2004 - 13:23
If you only install the old version (not upgrade), and uninstall it, do these files get removed? (Otherwise it's a problem in your old version)
Posted 23 August 2004 - 14:04
Seems old product uninstall stopped to remove files.
But RemoveFiles standard action exist in uninstallation log:
| Action start 16:50:39: RemoveFiles. Action ended 16:50:39: RemoveFiles. Return value 1. Action start 16:50:39: RemoveFolders. Action ended 16:50:39: RemoveFolders. Return value 1. |
Where is the problem?
Posted 23 August 2004 - 14:11
Posted 23 August 2004 - 14:44
Components is not permanent, cause of attribute field in Components table:
msidbComponentAttributesSharedDllRefCount (8)
When files removed, log file content GenerateScript message:
| Action start 17:22:09: RemoveFiles. GenerateScript: Removing files Action ended 17:22:09: RemoveFiles. Return value 1. |
In my occurence it is not.
Thank you.
Posted 23 August 2004 - 19:23
You need to find out why this action doesn't execute. Maybe there's a conditon on it?
Posted 24 August 2004 - 09:13
My installation log did not contain message: “GenerateScript: Removing files”
| Action start 16:50:39: RemoveFiles. Action ended 16:50:39: RemoveFiles. Return value 1. |
On the contrary, other installation log contain this:
I believe components is not permanent and not shared.
If I install a base product in clean system, base product installed and removed without any problem.
But if I once install major upgrade product, after uninstall latter all files, contained in base product, remain.
If I try to remove files for base product manually and install base product, after uninstall this base product all files remain!
I suspect major upgrade product corrupt Windows Installer repository.
Perhaps, it leave some registry keys (for instance, reference counts).
Zip log files of major upgrade in attachment, but there is no explicit errors.
Thank you.
Posted 24 August 2004 - 17:28
Posted 25 August 2004 - 03:47
When doing a major upgrade I have seen this "files remain" problem before, and as I recall it was because I either changed a component GUID for an existing file, or removed a file and then added it again with a new GUID (essentially the same operation).
Posted 25 August 2004 - 03:48
Posted 25 August 2004 - 07:15
It's resolved.
According to your assumption, in previous installation components defined as Shared.
Regardless to change component type in next installation packages, reference counts remain in target system.
After that I remove it from registry: HKLM\Software\Microsoft\Windows\CurrentVersion\SharedDlls
Certainly, I did not change component GUID not changed.
Thank you again, sorry for inconvenience.
Posted 25 August 2004 - 09:26
