Setup must install extensions for some program. In a PC can be different versions of this program and user must be able to choose versions for which extensions must be installed.
There is shared files and files specific for each version. For the first look it is not to hard to implement this- one shared component and specific components belonging to different features for each version.
Problem is that user must choose point where is installed each version of this program.
_How to allow for user to browse for destination folder for each feature?_
For each feature choosing destination
progdis
, Mar 29 2004 10:06
Posted 30 March 2004 - 04:16
You should be able to add a browse button in the dialog, and make the folder selection entry field point to the feature install path for each feature.
So if you have 10 features, you will need different browse buttons and entry fields.
Posted 30 March 2004 - 08:51
You can do it with one browse button. Just make sure these component have different Destination properties, and their associated features use the same destination property. Then they can select the features one by one and chenge the destination to the correct path.
