2) you must also select "Cache Installation on local machine" (two dialogs further down) or you will NOT be able to apply a patch.
You will get:
"Error 1706. No valid source could be found for product <your product>. The Windows Installer cannot continue."
If this is works-as-designed, InstallShield should put a little more information to this effect on the "Cache installation on local machine" dialog.
