Can I dynamically disable a "Cancel" pushbutton in "SetupProgress" dialog after running some action, which was included in installation script between InstallInitialize and InstallFinalize ?
Thanks in advance.
Enable/Disable Button
RomanBK
, Apr 05 2002 10:48
Posted 12 April 2002 - 20:47
If your custom actions are immediatelly, then you can set after they a property like DISABLECANCEL as 1 and use this property in a dialog to set the Cancel button as Disable. So
1. create a custome action to set a property,
2. include(run) this action after yours desired actions,
3. go to the Designer User Interface/Dialogs/SetupProgress/Behavior, select a ControlName Cancel, select Conditions and set
Action Condition
Disable DISABLECANCEL=1
The Cancel button should be disable if this property equals 1.
Action Condition
Irina Shirinsky
Software Engineer, Heroix Corporation
http://www.heroix.com
