Here is what I did to create a condition
1. Created an entry in Appsearch table with property name as LAUNCHCONDITIONDATA
2. Created an entry with the key value in Reglocator table. (See Q103290 for complete description on how I created the entries in these tables)
3. in the condition field of the custom action, I wrote
!LAUNCHCONDITIONDATA, so that if the regentry is found LAUNCHCONDITIONDATA returns TRUE and the NOT operator changes it to FALSE so that custom action wont be executed. but the not opertion is not working at all. When I remove the NOT operator everything works fine.
Is there syntax mistake in NOT operation or what else I am doing wrong.
I also tried to create a function to do the same instead of creating entries in the table but when I inserted the custom action that calls this function into the sequence, nothing happens, the installer does not even open any windows, it shows the dialog box saying initializing the installer and dies.
Any help is really appreciated.
Prasad
