hello
i made a installer with installshield
basic msi project
and i install 2 executes to the program files dir
i would like to execute 1 of them after instalation (alwais execute, so no user interaction)
but the program will need administrator rights
(the program makes an ini file with login data)
how do i set this in the installscript ?
atm i got this:
lauch program after instalation as administrator
bertyhell
, Feb 02 2009 15:31
Posted 02 February 2009 - 15:31
| function MyFunction(hMSI) begin LaunchApp(INSTALLDIR ^ "getlogin.exe", ""); end; |
Posted 02 February 2009 - 16:12
No InstallScript needed. You can launch an EXE directly as a custom action. If it needs admin rights (waring - potential security issue) then your setup should be launched using setup.exe which is flaggged as requireing admin rights.
