I have a installation which was developed in Installshield 6.12. For some reason, *.sys files which should be copied to the System32 folder don't get transferred in Vista. It works fine in older OS's. Any suggestions.
Installing (*.sys) files in System32 folder(Vista)
rajkulkarni
, May 07 2007 18:59
Posted 08 May 2007 - 14:18
How are these SYS files being deployed? Are they copied via InstallScript code, are they in a file group which says don't overwrite newer date/version, or what?
Posted 08 May 2007 - 16:45
These are Active X Controls (ocx) which go in System32, or *.sys files which I am trying to place in the "WINSYSDIR/drivers" subfolder. These files are in a file group, with the "ALWAYS OVERWRITE" option set. These files are not overwriting any existing files in the WINSYSDIR or the WINSYSDIR/drivers folder. They just won't go into that folder.
The installation works fine in Win2k and WinXp, but not in Vista.
Posted 09 May 2007 - 00:19
Okay, well in that case, I would try deploying them via InstallScript code and see what error codes you get back.
As a comparison, I would also try copying them manually via Windows Explorer and see how you make out there.
Finally, depending on those previous results, I would probably recommend you update to IS v6.34 as at least that verison officially supports Windows XP as well as includes other fixes/improvements which may help you on Vista.
Posted 09 May 2007 - 14:38
BTW, copying the files using Windows Explorer works just fine. I will probably just upgrade to Installshield 12 Professional.
