Hi All,
In converting IS MSI projects from version 6.21 to 12, I've found that the SdWelcome text at the beginning of the install is truncated in the newer version. I don't see any documentation about this. Can anyone suggest a workaround, or do I simply need to reduce the text?
Thanks very much.
SdWelcome character limit
Mariscal
, Jul 15 2008 19:40
Posted 16 July 2008 - 14:15
Have you tried to make the text box control larger, in the dialog editor?
Posted 16 July 2008 - 19:09
Yes, but unfortunately, that only added "gray" space around the InstallShield bitmap containing the text, which is still truncated.
Posted 17 July 2008 - 12:22
Are you sure you changed the correct control? Not the whole dialog, not a bitmap, but the static text control.
Posted 31 July 2008 - 00:56
Thanks Stefan, that was the problem: I was not editing the dimensions of the text field.
