I am working on installshield MSI project using IS10.5 professional.
I am trying to remove ( uninstall ) application from the shortcut created during the installation[ B](strat-program-Applicatoin name-/repair or Remove application)[/B] . There is some GUI sequence is while removal(uninstall) . But the GUI is not displyed if i try to uninstall from the shortcut.
The Arguments in the shortcut is given below.
Repair/Remove shorcut
Arguments : /x {Product code}
If i try to remove it form the control panel/add remove programs
then the uninstallation shows all the required GUI sequence before uninstallation. Then what is wrong with short cut menu?
In Addition to this : With the Arguments : /I {Product code} /qf
if tryto remove from shortcut
windows installer pops up the Dialog showing " 1:" message and abort. (see the attachment)
as per the Help /qf is used for FULL GUI option. i dont know how to do this? am i doing anything wrong ?
please help me.
Thanks ,
Shekhar
Uninstall in Installscript MSI project.
Shekhar
, Dec 21 2005 06:21
Posted 21 December 2005 - 06:30
i apologies for inconvenience caused...
by mistake i posted the my query in this forum.
this my first query ....
Shekhar
Shekhar
Posted 21 December 2005 - 09:31
Shekhar
Following topic is related to MSIExe.exe command line parameters, which is the Windows Installer Service for MSI based installers. This might be helpful to you in solving Shortcut problem:
MsiExe.exe Command line parameters
(http://helpnet.macrovision.com/robo/projects/installshield10-5helplib/IHelpCmdLineMSI.htm)
For "Creating Uninstallation Shortcuts for InstallScript MSI Projects" please see
(http://helpnet.macrovision.com/robo/projects/HelpLib/ShortcutUninstall_Standard.htm)
I hope that would help.
Farrukh
Farrukh
