We are tryng to generate a new installation msi, and then a new patch for our application. The problem is that we have to add some new files to it. I have read though your update rules and have come across a problem and it concerns the following section:
"If you want to add a component, you must put it in a new feature. This can be an invisible sub feature of an existing feature. To synchronize the installation state of a new child feature with its parent feature, set its Remote Installation property to "Favor Parent" and its Required property to yes. Or set the ADDLOCAL property to the name of the new feature. Note that you cannot combine this with REINSTALL=ALL. Instead use REINSTALL=ExistingFeature1,ExistingFeature2 ADDLOCAL=NewFeature."
We have added a new file in the above way, by adding a new feature which is a subfeature of an already existing feature. We have marked the file to "msidbFeatureAttributesFollowParent" and for "msidbFeatureAttributesUIDisallowAbsent" as you recommend but when we do the command line "msiexec.exe /I new.msi REINSTALL=ALL REINSTALLMODE=vomus" it succesfully patches all of the files already existing but doesn't install the new files. Why not???
The quote above from your tips says that new files will be installed, why aren't they?
The only way it will install the new files is if we use the ADDLOCAL property, but ve don't want to use the command line with the ADDLOCAL property because this will mean that the feature is installed all the time and we only want it to be installed if it's parent was already installed. Is it possible to do this?
We are using Orca to edit the msi database.
Adam
