Hi!
I have the following problem with my IS Dev 8 built setup program:
At the first time i start the resulting setup.exe, everything works fine.
At the second time i see the Maintenance-Dialog, ok, thats right.
But when i choose "Repair" at this point, then there is no Maintenance-Dialog appearing when i start the setup.exe for the third time!
It starts an "normal/first" installation with license-agreement!
How can i get rid of this behaviour?
Falk.
No Maintenance After a Repair
ichfalk
, Feb 03 2006 11:37
6 replies to this topic
Posted 03 February 2006 - 12:55
When you started the setup.exe for the third time, was it from the RUN button of the IS Dev 8. I ask this because I know that it never run the setup in maintenance mode.
If it can't help you, show us the logfile
Posted 03 February 2006 - 14:27
i run the setup on an virtual machine...
which part of the logfile do you want to see?
falk.
falk.
Posted 03 February 2006 - 14:47
alright, here are the three logfile-beginnings...
first run, "normal" installation:
=== Verbose logging started: 2/3/2006 14:24:39 Build type: SHIP UNICODE 3.00.3790.2180 Calling process: C:\WINDOWS\system32\MSIEXEC.EXE === MSI (c) (60:0C) [14:24:39:263]: Resetting cached policy values MSI (c) (60:0C) [14:24:39:263]: Machine policy value 'Debug' is 0 MSI (c) (60:0C) [14:24:39:263]: ******* RunEngine: ******* Product: C:\Documents and Settings\Administrator\Desktop\install\Setup\ReportServerComponent\ReportServerComponent.msi ******* Action: ******* CommandLine: ********** MSI (c) (60:0C) [14:24:39:263]: Machine policy value 'DisableUserInstalls' is 0 MSI (c) (60:0C) [14:24:39:283]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Documents and Settings\Administrator\Desktop\install\Setup\ReportServerComponent\ReportServerComponent.msi' against software restriction policy MSI (c) (60:0C) [14:24:39:283]: Note: 1: 2262 2: DigitalSignature 3: -2147287038 MSI (c) (60:0C) [14:24:39:283]: SOFTWARE RESTRICTION POLICY: C:\Documents and Settings\Administrator\Desktop\install\Setup\ReportServerComponent\ReportServerComponent.msi is not digitally signed MSI (c) (60:0C) [14:24:39:283]: SOFTWARE RESTRICTION POLICY: C:\Documents and Settings\Administrator\Desktop\install\Setup\ReportServerComponent\ReportServerComponent.msi is permitted to run at the 'unrestricted' authorization level. MSI (c) (60:0C) [14:24:39:523]: Cloaking enabled. MSI (c) (60:0C) [14:24:39:523]: Attempting to enable all disabled priveleges before calling Install on Server MSI (c) (60:0C) [14:24:39:563]: End dialog not enabled MSI (c) (60:0C) [14:24:39:563]: Original package ==> C:\Documents and Settings\Administrator\Desktop\install\Setup\ReportServerComponent\ReportServerComponent.msi MSI (c) (60:0C) [14:24:39:563]: Package we're running from ==> C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\186c1.msi MSI (c) (60:0C) [14:24:39:573]: APPCOMPAT: looking for appcompat database entry with ProductCode '{41D9E4AD-AD38-4B16-90F1-51E387100F7F}'. MSI (c) (60:0C) [14:24:39:573]: APPCOMPAT: no matching ProductCode found in database. MSI (c) (60:0C) [14:24:39:573]: MSCOREE not loaded loading copy from system32 MSI (c) (60:0C) [14:24:39:583]: Machine policy value 'TransformsSecure' is 0 MSI (c) (60:0C) [14:24:39:583]: User policy value 'TransformsAtSource' is 0 MSI (c) (60:0C) [14:24:39:583]: Note: 1: 2262 2: MsiFileHash 3: -2147287038 MSI (c) (60:0C) [14:24:39:583]: Machine policy value 'DisablePatch' is 0 MSI (c) (60:0C) [14:24:39:583]: Machine policy value 'AllowLockdownPatch' is 0 MSI (c) (60:0C) [14:24:39:583]: Machine policy value 'DisableLUAPatching' is 0 MSI (c) (60:0C) [14:24:39:583]: Machine policy value 'DisableFlyWeightPatching' is 0 MSI (c) (60:0C) [14:24:39:583]: APPCOMPAT: looking for appcompat database entry with ProductCode '{41D9E4AD-AD38-4B16-90F1-51E387100F7F}'. MSI (c) (60:0C) [14:24:39:583]: APPCOMPAT: no matching ProductCode found in database. MSI (c) (60:0C) [14:24:39:583]: Transforms are not secure. MSI (c) (60:0C) [14:24:39:583]: Command Line: SETUPEXEDIR=C:\Documents and Settings\Administrator\Desktop\install\Setup\ReportServerComponent CURRENTDIRECTORY=C:\Documents and Settings\Administrator\Desktop\install\Setup\ReportServerComponent CLIENTUILEVEL=0 CLIENTPROCESSID=352 MSI (c) (60:0C) [14:24:39:583]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{411B31E8-E4EC-4144-8B0C-55C3A69C5075}'. MSI (c) (60:0C) [14:24:39:583]: Product Code passed to Engine.Initialize: '' MSI (c) (60:0C) [14:24:39:583]: Product Code from property table before transforms: '{41D9E4AD-AD38-4B16-90F1-51E387100F7F}' MSI (c) (60:0C) [14:24:39:583]: Product Code from property table after transforms: '{41D9E4AD-AD38-4B16-90F1-51E387100F7F}' MSI (c) (60:0C) [14:24:39:583]: Product not registered: beginning first-time install |
second run, maintenance-dialog and repair-action:
=== Verbose logging started: 2/3/2006 14:28:20 Build type: SHIP UNICODE 3.00.3790.2180 Calling process: C:\WINDOWS\system32\MSIEXEC.EXE === MSI (c) (F4:FC) [14:28:20:111]: Resetting cached policy values MSI (c) (F4:FC) [14:28:20:111]: Machine policy value 'Debug' is 0 MSI (c) (F4:FC) [14:28:20:111]: ******* RunEngine: ******* Product: C:\Documents and Settings\Administrator\Desktop\install\Setup\ReportServerComponent\ReportServerComponent.msi ******* Action: ******* CommandLine: ********** MSI (c) (F4:FC) [14:28:20:121]: Machine policy value 'DisableUserInstalls' is 0 MSI (c) (F4:FC) [14:28:20:171]: Cloaking enabled. MSI (c) (F4:FC) [14:28:20:171]: Attempting to enable all disabled priveleges before calling Install on Server MSI (c) (F4:FC) [14:28:20:211]: End dialog not enabled MSI (c) (F4:FC) [14:28:20:211]: Original package ==> C:\Documents and Settings\Administrator\Desktop\install\Setup\ReportServerComponent\ReportServerComponent.msi MSI (c) (F4:FC) [14:28:20:211]: Package we're running from ==> C:\WINDOWS\Installer\1c44d.msi MSI (c) (F4:FC) [14:28:20:221]: APPCOMPAT: looking for appcompat database entry with ProductCode '{41D9E4AD-AD38-4B16-90F1-51E387100F7F}'. MSI (c) (F4:FC) [14:28:20:221]: APPCOMPAT: no matching ProductCode found in database. MSI (c) (F4:FC) [14:28:20:221]: MSCOREE not loaded loading copy from system32 MSI (c) (F4:FC) [14:28:20:231]: Note: 1: 2262 2: MsiFileHash 3: -2147287038 MSI (c) (F4:FC) [14:28:20:231]: Machine policy value 'DisablePatch' is 0 MSI (c) (F4:FC) [14:28:20:231]: Machine policy value 'AllowLockdownPatch' is 0 MSI (c) (F4:FC) [14:28:20:231]: Machine policy value 'DisableLUAPatching' is 0 MSI (c) (F4:FC) [14:28:20:231]: Machine policy value 'DisableFlyWeightPatching' is 0 MSI (c) (F4:FC) [14:28:20:231]: APPCOMPAT: looking for appcompat database entry with ProductCode '{41D9E4AD-AD38-4B16-90F1-51E387100F7F}'. MSI (c) (F4:FC) [14:28:20:231]: APPCOMPAT: no matching ProductCode found in database. MSI (c) (F4:FC) [14:28:20:231]: Transforms are not secure. MSI (c) (F4:FC) [14:28:20:231]: Command Line: SETUPEXEDIR=C:\Documents and Settings\Administrator\Desktop\install\Setup\ReportServerComponent CURRENTDIRECTORY=C:\Documents and Settings\Administrator\Desktop\install\Setup\ReportServerComponent CLIENTUILEVEL=0 CLIENTPROCESSID=2292 MSI (c) (F4:FC) [14:28:20:231]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{411B31E8-E4EC-4144-8B0C-55C3A69C5075}'. MSI (c) (F4:FC) [14:28:20:231]: Product Code passed to Engine.Initialize: '{41D9E4AD-AD38-4B16-90F1-51E387100F7F}' MSI (c) (F4:FC) [14:28:20:231]: Product Code from property table before transforms: '{41D9E4AD-AD38-4B16-90F1-51E387100F7F}' MSI (c) (F4:FC) [14:28:20:231]: Product Code from property table after transforms: '{41D9E4AD-AD38-4B16-90F1-51E387100F7F}' MSI (c) (F4:FC) [14:28:20:231]: Product registered: entering maintenance mode |
third action, NO maintenance and "normal" installation:
=== Verbose logging started: 2/3/2006 14:28:45 Build type: SHIP UNICODE 3.00.3790.2180 Calling process: C:\WINDOWS\system32\MSIEXEC.EXE === MSI (c) (70:78) [14:28:45:807]: Resetting cached policy values MSI (c) (70:78) [14:28:45:807]: Machine policy value 'Debug' is 0 MSI (c) (70:78) [14:28:45:807]: ******* RunEngine: ******* Product: C:\Documents and Settings\Administrator\Desktop\install\Setup\ReportServerComponent\ReportServerComponent.msi ******* Action: ******* CommandLine: ********** MSI (c) (70:78) [14:28:45:817]: Machine policy value 'DisableUserInstalls' is 0 MSI (c) (70:78) [14:28:45:827]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Documents and Settings\Administrator\Desktop\install\Setup\ReportServerComponent\ReportServerComponent.msi' against software restriction policy MSI (c) (70:78) [14:28:45:827]: Note: 1: 2262 2: DigitalSignature 3: -2147287038 MSI (c) (70:78) [14:28:45:827]: SOFTWARE RESTRICTION POLICY: C:\Documents and Settings\Administrator\Desktop\install\Setup\ReportServerComponent\ReportServerComponent.msi is not digitally signed MSI (c) (70:78) [14:28:45:838]: SOFTWARE RESTRICTION POLICY: C:\Documents and Settings\Administrator\Desktop\install\Setup\ReportServerComponent\ReportServerComponent.msi is permitted to run at the 'unrestricted' authorization level. MSI (c) (70:78) [14:28:45:858]: Cloaking enabled. MSI (c) (70:78) [14:28:45:858]: Attempting to enable all disabled priveleges before calling Install on Server MSI (c) (70:78) [14:28:45:898]: End dialog not enabled MSI (c) (70:78) [14:28:45:898]: Original package ==> C:\Documents and Settings\Administrator\Desktop\install\Setup\ReportServerComponent\ReportServerComponent.msi MSI (c) (70:78) [14:28:45:898]: Package we're running from ==> C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\549d2.msi MSI (c) (70:78) [14:28:45:918]: APPCOMPAT: looking for appcompat database entry with ProductCode '{41D9E4AD-AD38-4B16-90F1-51E387100F7F}'. MSI (c) (70:78) [14:28:45:918]: APPCOMPAT: no matching ProductCode found in database. MSI (c) (70:78) [14:28:45:918]: MSCOREE not loaded loading copy from system32 MSI (c) (70:78) [14:28:45:918]: Machine policy value 'TransformsSecure' is 0 MSI (c) (70:78) [14:28:45:918]: User policy value 'TransformsAtSource' is 0 MSI (c) (70:78) [14:28:45:918]: Note: 1: 2262 2: MsiFileHash 3: -2147287038 MSI (c) (70:78) [14:28:45:918]: Machine policy value 'DisablePatch' is 0 MSI (c) (70:78) [14:28:45:918]: Machine policy value 'AllowLockdownPatch' is 0 MSI (c) (70:78) [14:28:45:918]: Machine policy value 'DisableLUAPatching' is 0 MSI (c) (70:78) [14:28:45:918]: Machine policy value 'DisableFlyWeightPatching' is 0 MSI (c) (70:78) [14:28:45:928]: APPCOMPAT: looking for appcompat database entry with ProductCode '{41D9E4AD-AD38-4B16-90F1-51E387100F7F}'. MSI (c) (70:78) [14:28:45:928]: APPCOMPAT: no matching ProductCode found in database. MSI (c) (70:78) [14:28:45:928]: Transforms are not secure. MSI (c) (70:78) [14:28:45:928]: Command Line: SETUPEXEDIR=C:\Documents and Settings\Administrator\Desktop\install\Setup\ReportServerComponent CURRENTDIRECTORY=C:\Documents and Settings\Administrator\Desktop\install\Setup\ReportServerComponent CLIENTUILEVEL=0 CLIENTPROCESSID=2416 MSI (c) (70:78) [14:28:45:928]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{411B31E8-E4EC-4144-8B0C-55C3A69C5075}'. MSI (c) (70:78) [14:28:45:928]: Product Code passed to Engine.Initialize: '' MSI (c) (70:78) [14:28:45:928]: Product Code from property table before transforms: '{41D9E4AD-AD38-4B16-90F1-51E387100F7F}' MSI (c) (70:78) [14:28:45:928]: Product Code from property table after transforms: '{41D9E4AD-AD38-4B16-90F1-51E387100F7F}' MSI (c) (70:78) [14:28:45:928]: Product not registered: beginning first-time install |
hope that helps you helping me...
falk.
Posted 03 February 2006 - 15:49
No idea, sorry
Are you sure that your maintenance mode don't unregister somthing?
Posted 03 February 2006 - 15:57
i started a basic msi-project,
added 1 feature with 2 components (one file per component, only copy),
inserted a custom action which edits three files on the target machine by a vbscript (config of report server),
...and then build it.
falk.
falk.
Posted 06 February 2006 - 09:57
As far as I observed from the log files, after you have run the second installation, your product is getting unregistered. Then, when you are starting the third installation, a normal installation is running. And another thing is that when the initialization is starting, at third time, an empty string is passed for the initialization.
Try to check why you product is unregistered after you run the second installation; I think something is related to maintenance mode – some conditions or something related.
