Hi all.
I'm working on Basic MSI project on InstallShield X.
I have to set full-access permission to directory [INSTALLDIR] and registry
HKEY_LOCAL_MACHINE\Software\<VenderName>\<ProductName> for the local
user of Users group.
After installation, the [INSTALLDIR] get full-access permission but the registry did not.
I tried as follows:
1. Select the registry key in [System]->[registry] view,
and select privilege in right-click menu.
2. added new item of
Domain : (leave empty)
User : Users
and set full-access checked.
Basically the same procedure for [INSTALLDIR].
The installation checks Administrative privilege so the user must have Admin privilege on installation.
Anyone successes to set privilege to registry ? Or something wrong in my procedure ?
Please help, thanks in advance.
setting registry privilege does work ?
tktk
, Nov 18 2004 08:35
Posted 22 November 2004 - 01:35
Hi again, I have resolved the issue.
The detailed situation for the registry was as follows:
HKLM +- Software +- <Vender> +- <ProductName> +- <Version> +- subkey1 +- subkey2 |
I have tried to set permission to <ProductName> key and have failed.
Now I tried to set permission to subkey1 and subkey2, and this was done successfully.
And <ProductName> and <Version> keys, which was created by my installation, got the same permission as subkeys. This behaviour is consistent with InstallShield KB Q107639:
http://support.insta...ticleid=Q107639
I'm not sure why IS (or WI?) behaves such that, but the result is fine.
