Hi there,
I alreadly read lot of replies.
seems that IS DEV doesn't support or nobody knows:
in Dev 8, how to pass data into one-click setup from web, and pass data back to server.
These can be done easily in IS Prof 7.
Any guru/MVP/Traing Teacher knows, could you send me a brief sample like what do in web and
what do in IS. I am new at IS DEV.
thanks a lot
how to pass data into and out of setup
spj
, Aug 22 2003 18:38
Posted 26 August 2003 - 13:57
How do you invoke the setup? If you run msiexec.exe you can pass in property values on the command line. If you use Installer.InstallProduct you can also pass in property values.
