I will be getting parametrs from the user in the installshield, how can i pass it to the vbscript file which Iwill be executing using a wscript.exe. Could any one help me with some sample code.
shajil
Parameters to VBScript
shajilr
, Oct 08 2002 12:49
Posted 14 October 2002 - 16:19
Here's what someone posted to my question which was the same a few days ago:
Posted: Oct. 07 2002,08:24
Hi
The method for doing that is something like this"
Code Sample
function CreateMTSPackage2
Dim strPackageName, strComponentDir, strComponents, strIdentityType
Dim strDebug, bPackageUpdated, bPackageExists
Dim PropArray
' Get the installer properties
PropArray = Split(Session.Property("CustomActionData"), ";")
strPackageName = PropArray(0)
strComponentDir = PropArray(1)
strComponents = PropArray(2)
strDebug = PropArray(3)
bPackageUpdated = False
bPackageExists = False
Erase PropArray
This is just a fragment from the code but that's the idea.
In your project create a CA named "YourCAName" that will
set a property by the name "YourPropertyName"
Some thing like this:
nResult = MsiSetPropertyhMSI,"YourPropertyName",szValue);
Set the property before calling the VBS.
Note :
Use "CustomActionData" to get information from a Deferred Execution Custom Actions.
Otherwise you can use
PropArray = Split(Session.Property("YOURPROPERTY"), ";")
or something like this.
I'm sure if you look at the msdn you will find more information.
I hop this will help you.
--Yoav
>>>>>>>>>>>>>>>>>>>>>>&g
t;>>>>>>>>
I ended up doing two other things though.
First one was the convert the vbscript to a exe and then add that as a custom action (it will give you a line for command lines this way).
The other was to just go through the script and rewrite it to hard code the parameters I wanted.
Terry
Hi
Code Sample
Dim PropArray
Erase PropArray
Note :
--Yoav
>>>>>>>>>>>>>>>>>>>>>>&g
t;>>>>>>>>
Terry
