Does anybody know about any Data.cab tools, like ISCab.exe for InstallShield5.5, to replace, add, remove files from the Data.cab file.
Thanks for any help,
Data.cab tools
Irina
, Jun 03 2002 15:53
Posted 03 June 2002 - 15:53
Irina Shirinsky
Software Engineer, Heroix Corporation
http://www.heroix.com
Posted 06 June 2002 - 08:21
You can use Winzip, to extract the files out of the cab but I do not know of a way to add/remove files from a cab.
When I have tried this my install always fails because I think that the MSI keeps track of the information in the data.cab and if this changes the MSI doesnt like it that much.
Posted 10 June 2002 - 09:02
I'm using makecab.exe from MS; but don't ask me where it came from. I think it's part of platform sdk. It's a command line tool and can be integrated in automatic builds.
But I think you're looking for a tool allowing the replacement/adding etc. of files with a gui.
ATTENTION:
I don't believe it's possible to simply exchange files in a cab used by msi, because the file table contains file sizes and dates to check the files; for newer msi-versions there's even a hash based checking possible. Another problem might be that msi wants the files in a cab to be in exactly the same order as numbered (column Sequence in file table).
ATTENTION:
h.teichert-ott
Posted 11 June 2002 - 15:56
Thank you guys for your help. I know it is possible to extract files form the Data.cab file, but I don't know how zip they again in the .cab file. I'll try to look for anything on the Windows site.
Irina Shirinsky
