Hi
I got a problem at customer site, they try to install silent via Tivoli using command-line args., but repeately end up with error like this in the log file:
MSI © (C8:CC): Doing action: ISMsiServerStartup
Action start 08:07:37: ISMsiServerStartup.
MSI © (C8:CC): Creating MSIHANDLE (1) of type 790542 for thread 3788
Action ended 08:07:37: ISMsiServerStartup. Return value 1.
MSI © (C8:CC): Doing action: ISStartup
Action start 08:07:37: ISStartup.
MSI © (C8:CC): Creating MSIHANDLE (2) of type 790542 for thread 3788
1: The InstallScript engine version currently installed on this machine is adequate.
1: Event 'E738129' is created
1: GetInstallDriver, Can not find InstallDriver in ROT table, Return Code = 0x800401e3
1: {B376F08C-4964-439D-B822-2F0E4C49A17F}
1: Extract supporting files
1: Failed to extract _IsUser.dll, Ignore it.
1: Ev1813088
1: ISMsiServerStartup Failure, Failed to Open the shutdown event, Error 0x36b0
1: MsiServerStartup failed. Abort installation.
Action ended 08:07:39: ISMsiServerStartup. Return value 1603.
Action ended 08:07:39: ISStartup. Return value 3.
MSI © (C8:CC): Doing action: SetupCompleteError
Action start 08:07:39: SetupCompleteError.
Info 2898.Tahoma8, Tahoma, 0
Info 2898.TahomaBold10, Tahoma, 0
Action 08:07:39: SetupCompleteError. Dialog created
Action start 08:07:43: ISCleanUpFatalExit.
Action ended 08:07:43: ISCleanUpFatalExit. Return value 3.
DEBUG: Error 2896: Executing action ISCleanUpFatalExit failed.
Internal Error 2896. ISCleanUpFatalExit
Action ended 08:07:43: SetupCompleteError. Return value 3.
Action ended 08:07:43: INSTALL. Return value 3.
MSI © (C8:CC): Closing MSIHANDLE (1) of type 790542 for thread 3788
MSI © (C8:CC): Destroying RemoteAPI object.
We have checked following:
- Check DCOM setting permissions
- Short file name creation is disabled on the target machine.
- Increase DiskSpace requirement in Setup.ini and try again.
- Reinstall Windows Installer by running InstMsiW.exe file to reinstall.
- The Windows Temp folders are full
But still with no success.
Especially the row:
"1: ISMsiServerStartup Failure, Failed to Open the shutdown event, Error 0x36b0"
confuses me, I find no hits on this in this forum or Installshield forum.
What to do? Any clues?
BR /Tomassa
tomassa
, Aug 25 2004 13:43
Posted 29 April 2005 - 20:25
Bump...
I'm seeing this exact error too. Can't figure it out. We're doing a "silent" install of a vendor provided Setup.exe (meaning we didn't author the setup nor the MSI it contains).
Posted 02 May 2005 - 10:18
Hard to tell what's going wrong, especially without knowing the exact project type that was used to create the setup. I'd suggest you contact the author of the setup first.
Posted 25 August 2005 - 18:10
We are now experiencing this EXACT problem. The product is a McKesson product that installs fine if executed locally by a user with Admin privileges. However, if Tivoli installs the same program, we are recieving the exact message in the logs that the user posted in the OP.
We have spent a week going over EVERYTHING suggested when experiencing a 1603 error code, but to no avail. I, like the original poster, am curious to what
means, as it seems to be the root of the problem. I have found no mention of this message aside from this post.
Thanks for any advice.
Posted 07 September 2005 - 20:22
I suspect it's the same problem as discussed here:
http://community.ins...ad.php?t=149462
The problem seems to be which user the InstallScript engine tries to impersonate if setup is pushed unattended.
Unfortunately, I there doesn't seem to be a solution to this problem except getting rid of the InstallScript.
You could try playing with the DCOM settings (there's a KB artcile about that at support.installshield.com) maybe that would help in your case.
